0W-20 and 5W-30
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Dec 8, 2025.
  1. Jan 5, 2026 at 12:49 PM
    #211
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    I use 0w30 Redline and change every 10-12 months which is around 3-5K mileage. Some likely will faint from this heresy.
    Its ok though... I am doing my best to keep the oil workers..employed. :laugh:
  2. Jan 5, 2026 at 1:01 PM
    #212
    RSG sliders, Yakima Megawarrior basket, Black Rhino wheels, SOS Streamline bumper and skids, Warn VR EVO10S winch, OME MT64, Bilstein rear lift coils, Rigid Dually SS ditch lights, SR light bar, and Diode Dynamics SS3 fogs.
    Maybe you should reread my post. I said to read the manual and choose the appropriate interval for your usage.
    In the case of my previous 4Runner, which mostly got highway miles, was stock and rarely towed, I did a 10K interval. On my current 4runner, I do 5K oil changes due to modifications and the way that I use it.
    Actually, depending on your usage, you should be changing the oil more often. The manual recommends 5,000 miles, or every 6 months for special operating conditions. I'm basing this off my 2019 manual, but I assume they kept it the same.
    This has never been a consideration for me, because I have never driven a vehicle that I put that few of miles on. My current 2019 is coming up on 150k Miles, and it doesn't even get used for work.
    djwantke and Grug556[QUOTED] like this.
  3. Jan 5, 2026 at 1:06 PM
    #213
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics XPR reverse bulbs LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    3-5k has my vote as well. I constantly see engine failures from seized lifters or timing chain tensioners. Carbon buildup on rings is another one I see a lot. People treat the 10k oil change interval as gospel... It's intended obsolescence in disguise.
    3-5k changes with an oil that has a decent detergent will keep the engine clean. That alone means so much for the life of the engine.
    ACtC-3dl_ynMBwHt_KwkDyvsZwUqSQXM1tZ6_nDy_cfb9a3f678c4327be3f8e04b91e1fda34b2dadba.jpg
    And yes run thicker oil if your use case calls for it. Even the manual states to do so.
    Edit: @Thatbassguy makes a good point on the time interval. If your rig doesn't get much mileage 6 months is a good rule of thumb.
  4. Jan 5, 2026 at 1:10 PM
    #214
    Grug556
    Grug556 New Member
    I have two of these trucks. I put the most mileage on the 21 Limited and use Mobil 1 0w20. For the pig 16 I use the Redline. My mileage is really low on the pig. I think the manuals are the same from what ive seen on the 21 vs the 16. In the past ive run 5w30 and 10w30 in the summer. If you throw CAFE out the window it becomes more subjective, also even more so depending upon brand of oil you use.
    The 21 ironically with more mileage overall is harder on the oil than the 16. My wife use to have a job that was about 2 miles from the house, a nightmare for oil. Now her job is about 8 miles away, still not ideal for burning off impurities.
  5. Jan 5, 2026 at 1:14 PM
    #215
    It sounds like both of these vehicles should be getting the oil changed at least every 6 months.
    BC Hunter and 1SilverRunner like this.
  6. Jan 5, 2026 at 1:15 PM
    #216
    Grug556
    Grug556 New Member
    its close to that with the 16 going a few months longer as it sits alot. I havent driven it in three weeks right now.
  7. Jan 5, 2026 at 1:27 PM
    #217
    I agree with the first part of this, in that many people should be doing 5K intervals. As the manual states, there are many reasons to shorten the interval to 5K, or even less, depending on how much you drive and your driving style.
  8. Jan 5, 2026 at 1:29 PM
    #218
    1SilverRunner
    Tejas
    To hell with what you agree with sir.
    You're supposed to tell me, in great detail, exactly what you DISAGREE with. That's how this forum works.
    :poking:
    Thatbassguy[QUOTED] and Grug556 like this.
  9. Jan 5, 2026 at 1:30 PM
    #219
    3K oil changes. :crazy:
  10. Jan 5, 2026 at 1:35 PM
    #220
    Sorry. I'll try to do better next time.
  11. Jan 5, 2026 at 1:40 PM
    #221
    Mine actually sits a fair amount, as my work vehicle is pretty nice. But, I travel a lot, so I still manage to put probably 15-20 k on it every year. Between the 4Runner and my work truck, I have been averaging between 40 and 50K for the last five or six years.
  12. Jan 5, 2026 at 1:59 PM
    #222
    1SilverRunner
    Tejas
    Just joking bro. I'm surprised this oil debate thread is still going.
    Most of them get shut down in a page or two with comments claiming that canola or extra virgin is the way to go. Had to join the fun and see what the heck was keeping this one alive!
  13. Jan 5, 2026 at 2:15 PM
    #223
    1SilverRunner
    Tejas
    Wait hold up. The NUT really said that?
    ...That's hilarious.
    The most ludicrous thing I've heard him say was the full mark on the dipstick was actually overfull. And that filling it to the full mark could harm the engine... That was enough to get me off the nut's nuts
    3JOH22A[QUOTED] and Thatbassguy like this.
  14. Jan 5, 2026 at 2:15 PM
    #224
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Toyota switched to 0w20 in 2010 with a couple exceptions. The 2009 4Runner 1GR-FE did call for 5w30, but I believe it was VVT-i and
    not Dual VVT-i as the 2010-2024 is.
  15. Jan 5, 2026 at 2:28 PM
    #225
    CalcityRenegade
    Matt
    2023 T4R ORP KDSS
    Oil pumps are not programmed, nor care about the viscosity of the oil (Within reason).
    Thatbassguy and icebear like this.
  16. Jan 5, 2026 at 4:26 PM
    #226
    ^Yep, and that means using significantly higher viscosity oil (like xW40 or xW50) can result in higher oil pressure at operating temps and cause the oil filter bypass valve to open more often.
    1SilverRunner likes this.
  17. Jan 5, 2026 at 4:53 PM
    #227
    Yes according to him pre-filling an oil filter is #1 in "5 Car Myths That Are Actually a Bad Idea" :laugh:
    https://www.youtube.com/watch?v=pMk-lelAvyc&t=23s
  18. Jan 5, 2026 at 4:59 PM
    #228
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    Right. If you read it on the internet then it’s true .
    djwantke likes this.
  19. Jan 5, 2026 at 5:03 PM
    #229
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    hah
    229 comments in a month.
    couple resident asshole heavy hitters grabbed the first two comments
    @Dillusion @Turd Ferguson :)
    Turd Ferguson likes this.
  20. Jan 5, 2026 at 5:09 PM
    #230
    I dont think you can pull down any of your own posts. I tried when one instantly derailed, and Admins ignored me :p
  21. Jan 5, 2026 at 5:15 PM
    #231
    2020 Venture / 2017 Tacoma
    :nuclear:
    OP is to blame for getting us going down this path, this damn oil discussions always end up like this :duel:or like that:smack:
  22. Jan 5, 2026 at 5:15 PM
    #232
    ^He started a thread about his ex-mechanic friend calling up Amsoil the multi-level marketing company and speaking to a scientist, i.e. basically fiction. Can't expect a serious discussion to develop after that.
    4onto, BC Hunter and Grug556 like this.
  23. Jan 5, 2026 at 5:26 PM
    #233
    luckily for me guys, canada recommends 10k kilometer intervals for new and 5k for used, which makes no sense because USA recommends the same interval in miles…
    that’s only 6200kms and 3100kms.
    so I change early.
    BC Hunter likes this.
  24. Jan 5, 2026 at 5:47 PM
    #234
    Sin4R
    2024 4Runner Limited
    Mall crawling kit.
    nimby and Slopemaster like this.
  25. Jan 5, 2026 at 6:15 PM
    #235
    What do I win? Can you send me some Labatt Blue?
    nimby and Thatbassguy like this.
  26. Jan 5, 2026 at 6:20 PM
    #236
    1SilverRunner
    Tejas
    You’re saying they never bothered converting the units so you ended up with 3-6k mile oci recommendation?
    Canada finally got something right. (Even if it was by accident)
  27. Jan 5, 2026 at 6:31 PM
    #237
    they won’t admit that they simply
    never bothered converting, but they simply never bothered converting
  28. Jan 6, 2026 at 7:20 AM
    #238
    Where is this stated? The Canadian warranty booklet doesn't include maintenance intervals. Last I checked you'd have to enter some usage information on the Toyota Canada website and it spits out a customized maintenance schedule. Previously (until 2013?) the interval in the booklet were 8000 km and 16000 km.
  29. Jan 6, 2026 at 9:36 AM
    #239
    I'll admit I'm an ass but I didn't think this is considered me being one.
  30. Jan 6, 2026 at 5:24 PM
    #240
    No ya you were nice, I just used your clever tagline
