0W-20 and 5W-30
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Dec 8, 2025.
  1. Dec 24, 2025 at 3:12 PM
    #151
    22 ORP
    This is good detective work. Even more decisive would be to see if those same part numbers applied to 4Runners delivered to destinations where the owners manual specs 5w30.
  2. Dec 24, 2025 at 4:10 PM
    #152
    CarlP
    CarlP New Member
    Carl
    Phoenix, AZ
    2018 Off Road with KDSS
    That's nuts!
  3. Dec 24, 2025 at 5:20 PM
    #153
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Ummm... this statement meant to be humorous? :)
  4. Dec 24, 2025 at 8:16 PM
    #154
    Imdav2u
    23 TRD PRO
  5. Dec 24, 2025 at 9:08 PM
    #155
    22 ORP
    Not at all. I have seen it claimed, either in this thread or in one of the dozens like it, or in one of the many videos linked to therein, that though US models are spec’d for 0W20, there are different bearings in them than in foreign models that compensate for the thinner oil. If we could determine that is wrong, that definitively foreign 4Runners which are spec’d for 5W30 have the same bearings as domestic 4Runners spec’d for 0W20, that would finally lay to rest the debate about whether it is safe to run 5W30 in our domestic 4Runners.
    Or maybe I’ve just been hitting the eggnog a little hard.
  6. Dec 24, 2025 at 9:50 PM
    #156
    The 2010 owner's manual says this:
    So xW-30 oil is OK. For 5th gen's 1GR, Toyota added water jacket spacers to eliminate hot spots; that's what made the xW-20 oil safe for "non-extreme" usage. Conversely, xW-20 oil is unsafe to use in V6 4th gen 4R and 2nd gen Tacomas.
    4th gen:
    5th gen:
    Guppy1301 and Cisco Kid[QUOTED] like this.
  7. Dec 25, 2025 at 3:56 AM
    #157
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    One-at-this-price stripper. Bought new 36 yrs ago, a $13K leftover. Added Detroit TruTrac, 1”rear spring spacer and “pinstripes”… Factory AC kit and roof rack bought at dealer cost at time of purchase, still blows ice cold 36yrs later. 2022 AG ORP all stock.
    I live in the high desert, a few days/yr it might make it into the teens but usually in the the 30’s/40’s during the winter. 5-30 (warranty) in the 5th Gen 4R and seems fine. I run Rotella 5-40 in everything else…. truck, old 4R, 2 SxSs, 2 ATVs and my pressure washer. The old 4R has 250K+ miles and burns a shot glass of oil every oil change.
    Guppy1301 likes this.
  8. Dec 25, 2025 at 6:24 AM
    #158
    kouack
    kouack New Member
    Prov. Of Québec, Canada
    4Runner Limited 2024
    Bone stock
    So we will end this discussion(or not hahaha) 0W20 or 5W30! the answer use 0W30 all the great benefits on cold start from the 0W rating and the 30 weight @ running temperatures Merry Christmas 4Runner!5,4,3,2,1,go.
    BC Hunter likes this.
  9. Dec 25, 2025 at 7:59 AM
    #159
    BC Hunter and kouack[QUOTED] like this.
  10. Dec 25, 2025 at 8:15 AM
    #160
    kouack
    kouack New Member
    Bone stock
    Yes saw that, Walmart has/had mobile one 0w30 for 35 canuck dollars bought a few jugs (yes i know i said i would stick to what the oil cap says ) Look like you can get Pennzoil cheaper @ Wally also 40$ for a jug @ reg price.
    https://www.walmart.ca/en/ip/Mobil-...]&classType=REGULAR&athbdg=L3006&from=/search
    3JOH22A[QUOTED] likes this.
  11. Dec 25, 2025 at 1:54 PM
    #161
    Borracho Loco New Member
    That clip just showed up in my Youtube feed also, and I watched the whole thing. I actually learned a lot. Once I get closer to 60k, I'm switching to 5w 30. It will suit my use case perfectly.
    2Toys, BS67 and Imdav2u[QUOTED] like this.
  12. Dec 25, 2025 at 2:08 PM
    #162
    Imdav2u
    23 TRD PRO
    We moved my daughter to Tucson in August. She has a 2019 Rav4 with 38k. I think her next oil change will be 5w 30.
    BS67 likes this.
  13. Dec 25, 2025 at 2:57 PM
    #163
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Only synthetic blend 5W30 is being sold by dealerships. It appears Toyota does not have full synthetic OEM 5w30 for the US market.
    Back to the drawing board finding the best 5W30 now.
    BS67 likes this.
  14. Dec 26, 2025 at 5:27 AM
    #164
    AE1M
    AE1M New Member
    Bob
    2024 TRD Off-Raod Premium
    Thats exactly what he said.
  15. Dec 26, 2025 at 7:58 AM
    #165
    From the video:
    "Now here's the twist you probably weren't expecting. Viscosity isn't the whole story. Additives matter more. A premium synthetic 0w20 with strong base oil can outperform a cheap conventional 5w30. Detergents, anti-wear additives, high-temp stability......that's what keeps your engine alive."
    My takeaway from this statement is that if you use cheap oil like Kirkland Signature that barely passes the API rating then you should be using 5w30.
    If you're using a quality 0w-20 under normal conditions, your oil performance will exceed the cheap 5w30. For extreme conditions, a quality 5w30 is more appropriate than a quality 0w20.
  16. Dec 26, 2025 at 8:01 AM
    #166
    Taylor21554
    Taylor21554 New Member
    Naples Florida
    24 SR5 4x4
    The oil flow only provides a motive force to move the cam's. There position is controlled by the ECU and the loop closed by the CAM sensor. The only way oil viscosity could possibly affect that would be too low of oil pressure not creating enough hydraulic force to move the cam's. If anything thicker oil will cause higher pressure.
    Even as such the difference between 20 weight and 30 weight is pretty small at temperature.
    But my question still remains; how can viscosity of an oil affect a VVT cam position? We don’t even have variable oil pumps. It’s chain driven. Cmon guys
    ualfltdispatch likes this.
  17. Dec 26, 2025 at 9:02 AM
    #167
    Toyota made around 1.5 million 5th gen 4Runners. How many of them had engine failures due to the oil type?
  18. Dec 26, 2025 at 10:01 AM
    #168
    There's no way to know the answer that.
    But it doesn't change the fact that some oils perform better for not much more money.
    If you're trading a vehicle in at 200k, then you can probably get away with using cheap oil.
    If you're planning on going beyond 200k, I'm going to bet on the higher quality oil doing a better job in terms of longevity.
  19. Dec 26, 2025 at 10:06 AM
    #169
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    I am planning to go beyond 300k since I am already beyond 200k. So should I be switching to 5W30 or stick to 0W20, both higher quality versions of course.
  20. Dec 26, 2025 at 10:10 AM
    #170
    Since you plan on going high mileage with it, I think you should use higher quality oil no matter what.
    0w20 vs 5w30 depends on your climate and/or driving habits.
  21. Dec 26, 2025 at 10:18 AM
    #171
    I’m pretty sure we would be hearing about engine failures here. People come here to complain about their tires losing air. They would surely tell us about their engine seizing.
    Shredder and ualfltdispatch like this.
  22. Dec 26, 2025 at 10:19 AM
    #172
    The vast majority of people here trade before 200k miles.
    Shredder likes this.
  23. Dec 26, 2025 at 10:29 AM
    #173
    Also, I'm not talking about catastrophic engine failure due to use of Kirkland Signature.
    I'm just betting there would be fewer oil related issues (like oil consumption and/or oil burning) on higher mileage engines when using a higher quality oil with a good additive package.
  24. Dec 26, 2025 at 10:41 AM
    #174
    Yes but new members join all the time just to talk about their issues.
  25. Dec 26, 2025 at 12:29 PM
    #175
    Maybe you're right, but I'm not willing to take that bet on my vehicle.
    I'm ok spending an extra couple of dollars per quart on an oil that goes further than meeting minimum spec.
  26. Dec 27, 2025 at 12:21 PM
    #176
  27. Dec 27, 2025 at 12:28 PM
    #177
    Why do you stick with Toyota-branded oil?
  28. Dec 27, 2025 at 1:03 PM
    #178
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    I don't! I used it for the first time this past oil change at 210k just to try something new and actually preferred it over Mobil, Valvoline, Pennzoil etc. My engine appears to run smoother and quieter. Could be placebo.
    I am going to run Valvoline Restore and Protect next and then for the next 20k miles as required by Valvoline. BITOG members swear by it's performance.
  29. Jan 3, 2026 at 1:57 PM
    #179
    Cisco Kid
    Cisco Kid New Member
    Two days ago I changed the oil in one of our 4Runner’s and used 5W-30 Valvoline Restore and Protect. So far I have noticed that the engine does seem to run quieter than it did with 0W-20. I’ll give it another oil change with the same 5W-30 then send out a sample for evaluation.
    Here is one more video that Lake posted this morning with regard to this very topic.
    https://youtu.be/1OI2sXdrpdA?si=YSni7HFh6tlezJ2A
    5thToy, nimby and Lc200[QUOTED] like this.
  30. Jan 3, 2026 at 2:04 PM
    #180
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    If you really looking for it to work it's magic run it for 4 oil changes. How many miles on your 4runner?
    I will run 5W30 next, Mobile 1 ESP.
