07 4runner diff oil issue?
Discussion in '4th Gen 4Runners (2003-2009)' started by akhero, Sep 1, 2022.
  1. Sep 1, 2022 at 9:19 PM
    akhero
    akhero [OP] New Member
    Replaced my rear diff oil today in my garage almost a full gallon went in before started coming out from the fill plug I thought it takes more like 3 qts.
  2. Sep 2, 2022 at 5:29 AM
    hvac guy
    hvac guy New Member
    That's normal, was probably under filled from the factory. I have a 2022, when I got it I checked the rear diff and had to add 3/4 of a quart to get it full. Transfer and front diff were full.
  3. Sep 2, 2022 at 7:21 AM
    akhero
    Oh ok I think it was never replaced.
  4. Sep 2, 2022 at 7:25 AM
    hvac guy
    hvac guy New Member
    It doesn't evaporate or dissipate, but if you have a obvious leak then it will get low, or more than likely under filled from factory.
  5. Sep 2, 2022 at 7:28 AM
    It's easy to overfill them. I just did mine, and once I removed the filler tube, a bunch drained back out.
    It wouldn't matter if it had been under-filled from the factory, because you are draining it all out before you refill it anyway. So, you're starting with an empty differential either way.
    Was the vehicle sitting level when you filled it?
  6. Sep 2, 2022 at 8:07 AM
    akhero
    Yes, it was in my garage on level ground. Although i don't know if this makes any sense my shocks are shot and my rear end sits 3" higher than my front.
  7. Sep 2, 2022 at 8:20 AM
    They sit higher in the rear from the factory. Maybe not 3", but that shouldn't be an issue. I think they hold 3 quarts +, so you should ould have had less than a quart left, if you bought a gallon.
  8. Sep 2, 2022 at 2:44 PM
    akhero
    mope almost the whole thing went in i'd say 3qt and 700ml
