07 4.7 V8 engine knocking
Discussion in '4th Gen 4Runners (2003-2009)' started by 3mkennels77, Feb 23, 2025.
  1. Feb 23, 2025 at 3:30 PM
    3mkennels77
    3mkennels77 [OP] New Member
    A couple months my daughter 4runner ran fine one day, it sat for 2 days and on the 3rd day she started it up to go to work and it had a horrible knock and the knocking sped up while pushing the gas.
    I’ve been messing with it here and there as I am not a mechanic and no garage to really dig in to it.
    I did remove the valve covers and spark plugs. Drivers side valve cover had thick sludge and one spark plug was unusually clean.
    So I replaced the ignition coils with new and new spark plugs. Still has the knock.
  2. Feb 23, 2025 at 9:56 PM
    LOSTR4
    LOSTR4 New Member
    Just a couple
    How fresh is the oil and is it 5w30, or thinner? How many miles are on the truck?
  3. Feb 24, 2025 at 8:19 AM
    3mkennels77
    It was at the end of the oil life cycle. Oil levels were good. I always put the correct oil in and actually use high mileage oil. There’s roughly 203k
    LOSTR4 likes this.
  4. Feb 24, 2025 at 2:30 PM
    LOSTR4
    LOSTR4 New Member
    Just a couple
    Are you in a higher humidity part of the country that gets below freezing in the winter months?
  5. Feb 24, 2025 at 8:15 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Sludge is not good. There are lots of oil passageways inside the engine that may have been clogged and perhaps starved oil flow to critical internal components.
    Does the engine has a history of using conventional engine oil or synthetic engine oil?
    I suggest investigating de-sludging the engine.
    There are additives you can put in the engine and run it for hours, days or longer depending on the product. Seafoam is a product I have used on a long neglected rarely serviced aluminum GM V8 engine run on conventional oil even though synthetic was required by manufacturer.
    It rapidly turned new engine oil black with dissolved sludge.
    With luck your knock might lessen.
    LOSTR4 likes this.
