05 4runner drl.
Discussion in '4th Gen 4Runners (2003-2009)' started by Rajanbrar204, Sep 15, 2022.
  1. Sep 15, 2022 at 7:47 AM
    Rajanbrar204
    Rajanbrar204 [OP] New Member
    2005 4Runner V8 LIMITED
    2inch bilstein 5100 lift, 33inch tires. Fj cruiser springs and wheels. Air suspension delete. Gibson cat back exhaust
    So I have a 05 4runner limited. It has drls. Ones in bumper. So basically it uses a 4157 dual filament bulb. I bought switch back 4157. But clearly they were sh bc they were hard to fit. Either way I got it in and it didn’t function as switch back. Then I realized I only have two wires going to the socket. A power and ground( I looked up wiring diagrams on mitchel) so why tf does it use a dual Filomena if it can only power one filament? I took org halogen out. Started my truck. One Filomena’s on. Used the signal. All it does is flash the same filament . So why is there a dual bulb?? How do I get switch back bulbs to work
  2. Nov 18, 2022 at 3:01 PM
    kaidoy888
    kaidoy888 New Member
    Richie
    2005 SR5
    18" AR Rims, LED lighting all around.
    It is impossible to use any dual filament bulb with just 2 wires, BUT here's what you need to do:
    1 - Disable DRL via reprogramming, (procedure is available online - I saw it somewhere), or by changing your turn signal flasher to one without DRL.
    2 - Purchase 2 new 3157/4157 sockets, (with 3 wires), to replace your existing sockets.
    3 - Wire the original hot turn signal wire to the high/turn signal input wire of the new socket; the other wire of the socket gets wired to a Bosch type relay that provides 12V to the white light input of your switchback bulb,
    and turns on only when the ignition is on.
    I plan to do the same via a new adjustable turn signal flasher, as I installed LEDs, and they flash too fast. No problem with other LEDs, (headlights, dome, courtesy, reverse).
