04 V8 Doug Thorley Header Install Issue - Codes P0154 & P0051
Discussion in '4th Gen 4Runners (2003-2009)' started by gary87xj6, Mar 10, 2017.
  1. Mar 10, 2017 at 4:42 PM
    gary87xj6
    gary87xj6 [OP] New Member
    Eastern WA
    2004 V8 4Runner Limited
    Magnaflow muffler Doug Thorley headers K&N Drop in
    Ten minutes after the install the Check engine, VSC Trac and VSC Off lights came on. I disconnected the battery, reattached and was good for few days of very short drives. Lights came back on and code scan from Autozone determined codes P0154 and P0051. Any suggestions on what my next step should be? I just did the headers, everything else CAT wise is OEM with 55K miles.
    Thanks
  2. Mar 15, 2017 at 7:27 AM
    ajohnson
    ajohnson Glamorous
    Andy
    Charlotte, NC
    87 4Runner SAS and other stuffs, 07 Tacoma
    Things and stuff and such
    Who installed the headers? Are they short or long tube?
  3. Mar 15, 2017 at 7:55 AM
    gary87xj6
    Eastern WA
    Bonnie & Clyde's Muffler in Pasco, WA
    Short header
  4. Sep 5, 2020 at 8:04 AM
    ElShep
    ElShep New Member
    4.7 4runner
    Im currently experiencing the same issue after i had a shop install shorty DT headers. CEL, vsc off and vsc trac. any luck?
  5. Dec 3, 2020 at 8:19 AM
    cmaj91
    cmaj91 New Member
    2003 4.7L 4runner sport addition
    Doug Thorley short tube headers, y-pipe and gibson cat back exhaust
    Hello - very similar issue here. After install of DT short tube headers, magnaflow high flow cats, and Doug Thorely y-pipe, showing CEL code p0051 (Bank 2, sensor 1 /passenger side upstream). Code indicates faulty heater control circuit in sensor, replaced sensor with KAX aftermarket unit, and same code - P0051.
    Note, per the retailer (Burtman Industries) who sold me the components provided 4 CEL spacers - 1 each for both upstream and downstream sensors for both sides. They were only installed at the downstream locaitons. Could not use the spaces on the passenger side upstream due to space constraints, so we did not install spacers on either of the upstream locationis. Also, spacers on upstream locations are not ever recommended - only downstream locaitons are. However, after calling back Jason at Burtman Industries, he mentioned that running high-flow CATS with Short tube headers is almost equivalent to running long tube headers without cats. For his long tube customers, he states that these headers need spacers in all 4 locations (upstream and downstream, both sides) to avoid and CEL/codes.
    So, he then recommended a low profile right angle spacer that will in fact fit on the passenger side. Tentatively, I could install this right angle on the upstream passenger side and see if it somehow tricks the sensor to not throw a code, but this does not really make sense for the purpose of the upstream sensor.
    Any suggestions ? Were you able to resolve your issue ?
  6. Dec 16, 2020 at 10:32 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    Also had very similar issue. 05 V8 with DT long tube headers, no cats, DT Y-pipe, BAM cat-back exhaust with 90-degree custom tip. Jason at Burtman Industries is...mostly correct. Blackout (I think) on T4R.org has a great write-up about this. Ultimate issue is that your ECU thinks your down stream sensors aren't reading right because the airflow going through right there isnt the same as having the regular low-flow stock cats. Upstream sensors need nothing, no spacers no anything. Do not touch them. Your down stream sensors are the only thing to ever touch. Pull up ebay and type in "O2 sensor mini catalytic converter" and search around. This is the exact one I bought. Your ECU needs to think the airflow is what would come out of a cat, so this tricks the sensor into producing the correct signal.
    https://www.ebay.com/itm/O2-Oxygen-Sensor-CEL-ELIMINATOR-Angled-Extender-Spacer-90-Degree-02-M18-X-1-5/392484288986
