04 4runner v8 no check engine light but vsc trac lights on
Discussion in '4th Gen 4Runners (2003-2009)' started by GPpete, Nov 8, 2022.
  1. Nov 8, 2022 at 3:13 PM
    GPpete
    GPpete [OP] New Member
    pete
    2004 v8 4runner limited
    white
    looking for new suggestions. the lights are on while driving, but no check engine light. mechanic plugged in the computer and there are no error codes popping up. someone suggested the swapping out the brake light switch. I replaced it but the lights stay on. thanks for any recommendations
    pete
  2. Nov 9, 2022 at 9:06 AM
    Daddykool
    VSC and TRAC lights come on when you start the engine, or only come on after the vehicle begins to move? I'm thinking possible ABS sensor problem. I had a shock absorber break one time (Gen3) and it speared the ABS wire, partially severing it. I did get an ABS error with that, as I recall.
  3. Nov 11, 2022 at 10:36 AM
    BackOff
    BackOff New Member
    2004 V6 4Runner
    Standard rabbit hole stuff
    Maybe a ZPC would fix it.
    Zero point calibration.
    Really easy to diy.
    Not sure if this site has detailed info on it, i dont spend much time here.
