03 4Runner will not accelerate under load
Discussion in '4th Gen 4Runners (2003-2009)' started by Kathy M., Aug 27, 2023.
  1. Aug 27, 2023 at 3:59 AM
    Kathy M.
    Kathy M. [OP] New Member
    03 4runner limited
    Hi there!
    I have an interesting (annoying) problem with my beloved 4Runner.
    I have an '03 Limited with about 230,000 miles with no modifications. In the last few months, I have been losing the ability to accelerate when at higher speed or uphill. The engine is revving high but the power isn't getting to the wheels. The kicker is that there are engine codes.
    I had it to a Toyota diagnostician, a friend, who couldn't seem to figure it out but he said that the driver side cat was running at like 600 degrees and the passenger cat was much lower. I swapped out the driver side cat and now the passenger side cat is hotter than the driver side and it still had the same problem. BTW, the cats on there were replaced in 2021 so they are relatively new.
    I replaced the MAF also but that had no impact.
    The car is drivable but a bit dangerous as I cannot climb steep hills or merge or pass!
    I am so deeply bummed out because I love this truck and it has been so good to me and I feel safe driving it.
    Any help would be appreciated!
  2. Aug 27, 2023 at 4:26 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    Please post what codes you have.
  3. Aug 27, 2023 at 5:23 AM
    Kathy M.
    03 4runner limited
    Heya. Thanks for looking! That's the problem--no codes. No codes on the diagnostic tool while driving, either
  4. Aug 27, 2023 at 6:02 AM
    High exhaust temperature could mean it's running lean. Maybe have the fuel system looked at. :notsure:
  5. Aug 27, 2023 at 6:13 AM
    Kathy M.
    03 4runner limited
    Thank you! I will run it by the mechanic but he's very puzzled because there is no smell, no stalling and no trouble starting to indicate running lean but I will def mention it to him.
    Thanks again!
  6. Aug 27, 2023 at 7:19 AM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    I asked for codes because you said in your original post......"The kicker is that there are engine codes."....I'm guessing now that you meant to type...The kicker is that there are no engine codes.
    Thatbassguy, xtremewlr and CygnusX-4 like this.
  7. Aug 27, 2023 at 7:32 AM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    Get your fuel pressure checked. I'd put my money on a weak fuel pump.
  8. Aug 27, 2023 at 9:15 AM
    Kathy M.
    03 4runner limited
    MY BAD! NOOOO CODES! Thank you AuSeeker!
