01 brake bleeding
Discussion in '3rd Gen 4Runners (1996-2002)' started by 01 4runner, Oct 30, 2022.
  1. Oct 30, 2022 at 10:51 PM
    01 4runner
    01 4runner [OP] New Member
    01 4runner
    Any advice on bleeding brakes have tried 8 different way from you tube gone through about 1/2 gallon of fluid still can't get them right haven't adjusted the rod on the pedal?
  2. Oct 31, 2022 at 2:09 AM
    6uam671_T4R
    6uam671_T4R New Member
    A little more detail of your issue will help. 1/2 gallon of fluid bled through the system should mean it has fresh fluid. What can’t you get right?
  3. Oct 31, 2022 at 12:50 PM
    01 4runner
    01 4runner
    The brakes just don't feel right to me if I have to slam on them it just doesn't want to stop as it should I was just wondering if I needed to bleed the a certain way or have a computer hooked up the 01 has the stupid brake pressure motor thing instead of the master cylinder and brake booster
  4. Oct 31, 2022 at 2:24 PM
    Startrek
    Startrek New Member
    time for new brake calipers. most probably piston(s) stuck.
  5. Oct 31, 2022 at 6:49 PM
    6uam671_T4R
    Does your brake pedal go to the floor when you open the bleeder valve? Mine didn’t until I got to the front passenger’s caliper. Did you recently change the rotors and pads? If so, you’d have to bed the pads but even then you’d have to take it easy for a couple hundred miles.
  6. Nov 1, 2022 at 2:37 PM
    01 4runner
    01 4runner
    New pads rotors calipers also rear shoes hardware and wheel cylinders no leaks in the lines
  7. Nov 1, 2022 at 2:49 PM
    6uam671_T4R
    It’s likely the new rotors and pads that need to be bedded. If you didn’t do the bedding on install, drive it normally for about 250-300 miles. You should feel a difference. Try not to do hard braking when coming to a stop.
  8. Nov 1, 2022 at 9:55 PM
    01 4runner
    01 4runner
    New symptom anti lock engaging when I stop?
  9. Nov 1, 2022 at 11:05 PM
    6uam671_T4R
    Wow! You’re probably going to have to start diagnosis from the master cylinder. Unless you have the proper tools, it’s probably time to take it to a knowledgeable shop. Keep us updated on your progress.
